Robbi Lockhart
So We have a 2010 AR210. Had it out and the starboard side dive start making a loud grinding noise. Sounded like a bad bearing and it was. So started taking the jet drive a part and found the back beari in peaces. The one on the end of the shaft in the ducy impeller. I wanted to take the rest a part to make sure everything is good and found the impeller had scratched the impeller housing. Impeller looked okay but will need to replace housing. The real problem is I can't get the drive shaft to come out. From everything I have watched looks like it just pulls out. Do not want to pound on it. So not sure what tod do.
