Need to help YAMAHA 255xe Surfpoinet/Transducer/Stereo/Joystick communication failure
tenl_710
255XE
My yamaha 255XE Only 15 hours have some problem. .o_Oo_Oo_Oo_O
The following failure occurred when the switch was turned on the next day.
Turn on the switch.Some alarms appear on the screen.First:Surfpoinet alarms. And then:Transducer/Stereo/Joystick/Bilge/Blower/Anchor failure alarms. Only the sound responds.
Check that there is no problem with the two PDMs behind the boat.
Go to the background of the boat system,no BCU and BALLSTER buttons.
Can anyone help with the following ????so sad。
微信图片_20220806220604.jpg微信图片_20220806220610.jpg微信图片_20220806220614.jpg微信图片_20220806220621.jpg微信图片_20220806220624.jpg微信图片_20220806220628.jpg微信图片_20220806220632.jpg
Did you ever resolve this? I just lit up my 2023 AR250 for the new season, and was greeted with the “Transducer Communication Failure” message, too.
Looking for the same answer from anyone. I was listen in g to the radio at home cleaning it and it kept going off every 5-10 minutes.
View attachment 184651View attachment 184652View attachment 184653View attachment 184654View attachment 184655View attachment 184656View attachment 184657
You're battery, at 12.1v, is low. Charge and then cycle the power 5-7x.
Screenshot this chart and keep it in your phone as a reference.
Thanks for the suggestion. In my case, the transponder was indeed bad and had to be replaced.
