Need Wiring Schematic 2016 AR192
red900
AR192
Can anyone help? Need the boat wiring, not just the motor.
All I have is the switch panel and ECM wiring diagrams for an SX/AR 190 out of the service manual. Most of it should be the same as our 192 boats. It doesn't show a wiring diagram for the entire boat though. What are you looking for specifically?
Thank you for responding. My dealer, whom is new to being a dealer this season, does not have access yet to a hull wiring diagram. They have the motor. They are trying to diagnose a Speed Comm Error on the dash. They have hooked up the YDS2 and cannot find any hardware problems. They swapped the gauges and no fix, so they are scratching their heads.
I have the same problem at the start of every year with my 16 sx192. After a few times out it goes away. I dont know exactly what causes it but checked the multisensor, I believe that is what is called, for the speed and water temp and it seems to be fine. The only aspect I find odd is that multimeter at battery reads around 13 volts when running and helm voltmeter reads around 11.7 volts. If you find a good answer to this issue, or if someone else knows of something please post.
Low voltage is usually the issue. If dual batteries make sure they are both fully charged.
Does anyone know the schematics to wire up aftermarket ignition switch?
Does anyone know where connector A goes from the schematics list? It's the one right next to the fuel pump. I know it goes into the "deck wiring harness", however what does it go to on the deck harness? Totally stumped.
