Torkrench
- Scarab
- 165 ID
I recently purchased a 165 ID. From the first time I put it in the water it has had a slight reverse thrust in neutral. If I move the shift lever slightly into the forward position, the reverse thrust goes away and it seems to be fine. I figure that can be fixed by adjusting the shift cable at the shifter assembly. The bigger problem is that twice now while playing around with some tight turns, the shifter has gone into neutral by itself. I was checking the reverse bucket position the other day and noticed that it didn't seem to raise all the way to the locking latch. Again, if the shift cable is out of adjustment, that should probably take care of that problem...
Here's the issue though, If you disconnect the shift cable from the reverse bucket and raise the bucket all the way until the locking latch catches, you can still manually pull the bucket back down without disengaging the latch. From what I can tell by looking at the mechanism, it seems that when pressure is applied by the shift cable, the lever is moved out of the locking position to allow the bucket to move out of it's locked upright position. The only way I can get my bucket to stay locked in place is to apply pressure to the lever keeping it from popping out of it's latched position. It looks like there is a spring that is supposed to keep pressure on the latch, but there's a lot of freeplay before the spring applies any force. It's almost like the spring is too small or bent and not acting on the lever the way it should.
I have seen a few other posts about the scarabs having issues with the reverse bucket lock like this and i haven't been able to find anyone who has found a solution yet. I'm ready to take it back to the dealer to have them check it out, but that's 2 hours each direction for me, and if it's something that can be adjusted easily, I'd rather do that and save myself a trip.
Could someone with a working boat check to see if out of the water with the shift lever in full forward you can manually rotate the bucket (and shift lever) back to the neutral position from the back by the jet? I figure the reason the locking mechanism is there is to prevent that from happening. It's not a fun feeling when the boat decides to go back to neutral when you are in the middle of a turn at partial throttle.
