- Ottawa, Canada
- Scarab
- 165 G
Glad you made some progress on the bucket issue. Too bad it's that hard to move the cable on yours.
As for porpoising, yes.... the problem with shorter boats... especially this one. I purchased Nauticus trim tabs... had to McGyver the parts from two different sets after speaking with the company. I got them installed and have been using them for the past 5-6 outings. I'm adjusting the pressure each time to try and find the optimal pressure to avoid porpoising. Have yet to remove it entirely but did improve it. I'm about to set it to the highest pressure this upcoming weekend to see how it behaves. Once I've tested it all thoroughly, I'm planning on writing a quick review of the results, parts, etc. If someone wants to try.
As for the nozzle angle, I had mine pointing down (i.e. causing the bow to go down deeper in the water) for 3 seasons. I switched it back to the default up position this spring. I've noticed no difference in top speed at all. So I don't think that's what's causing speed differences in this case. But I've been wrong before... lol
