CraigAR
- Cape coral, Fl
I took out the boat today and after getting it off the trailer and trying to reverse it, it did not sound right and had no power. I then put it in forward to try to get back to the dock and no go. This is where you dont want to panic but I will tell you I was nervous that there was a major issue. Once tied back at the dock the first thing I did was lift the engine hatch while the motors were still on to see if something came loose. Everything checked out fine. The next step, I went back to the clean out ports. Sure enough, they were not locked in. I've owned my boat for 2 years and never had this happen. I guess after washing it the previous week I did not twist them back in. Closed up the hatch, went up and gave it some throttle while still tied up and boom. We have power. Soooooo, if you have no power going forward or reverse, check on the simplest things first. I'll just leave it at that for any new people reading through the forums or even experienced boaters. Boat on people.....Its a yamaha!
