Ph2426
- SX
Hi all.
I have owned a 2012 sx190 for about a year and it has been very good and reliable. I used it on Sunday and I had a problem starting it. If I go to turn the key the accessories come on but every now and again it won’t crank. Almost as if it senses it’s not in neutral. I played with it in the garage today and when I turn the key I can hear a small click coming from the rear of the boat but it takes five or six turns of the key before any crank happens. I was going to call a mechanic to have them look at it but I thought I should post here first.
If I go from neutral to forward to back and back to neutral it doesn’t seem to make a difference. If I remove the lanyard and put it back it doesn’t make a difference. Sometimes I just hear a small click when I turn the key and other times it starts right up. The battery has charge and when it does crank it’s like normal.
it happened this weekend when in the water after being anchored and i don’t want to get stuck if it won’t start again. Any ideas? Thank you in advance
