steve0617
- Littleton CO
- AR195
2019 AR195
Replaced the roller with the Stoller. Even before then the boat never sits right against the roller. I've released the tension from the bow strap and this is how the boat settles. The boards are not tightened down and they rock a bit as they should so they can move when I retrieve but other than when I first bought the boat in Feb 19, it's never set correctly against the winch.
What's wrong here? Also, it almost looks like the entire winch assembly is bent when looking at it from the front, but it doesn't appear that way when you look at against the tongue.
