No Thrust - Help
BTJetboat
AR192
Hey Everyone,
I have 2014 AR192 that was sitting in storage for about 1.5 years. The boat only has 115 engine hours on it and I put it in the water this past week. Everything seem to be working fine and then roughly 30 mins into testing everything at max speed, the boat suddenly just lost thrust and engine cut off.
I was able to get the engine running and the boat would move in wake mode, but if I gave it anymore throttle, the RPMs would increase but the boat would not generate any thrust at all.
Any ideas?
Something was sucked up into the impeller. Pull the clean out plug to inspect.
I agree with checking the impeller, something small could be causing it.
My initial thoughts were bad gas and maybe a bad plug since the engine cut out at speed.
Clean out plug may not in or fully seated
