No wake mode issue?
Vaboater
I have a 2007 sx230, I recently changed out my bucket cables and had to tear into the throttle controls. I got everything back together and put it in the water today and my no wake mode won’t engage on the port motor, and the port button engages the no wake on the starboard. Also have to adjust the tension I’m assuming to sync the throttles up. How does the no wake work within the throttles? Could something be off in there causing that? Felt like a completely different boat with the new bucket cables its going to take some getting use to.
What's your idle rpm. On each engine?
There's a post in the faq about adjusting no wake sensitivity
Is your battery 100%, if not it can cause issues
I’m charging the battery now to make sure it’s good to go, rpm is right under 2000 I think
You have a pm
you were right I charged the battery and dropped it to change the bunk boards and they both worked just fine. Thanks for the info
