No wake mode vibration.
Ray525
So strange vibration noise coming when boat is put into no wake mode.this is the first time boat is out this season. Engine was fogged and gas stabilized, so not sure if i have to burn through that gas to sound normal.When driving with throttle pressed noise is gone...Any ideas??? (On lake wallenpaupack)
njmr2fan
Augusta GA
Everything vibrates on these boats. I stuffed my steering cable into a pool noodle where it rides under the floor plate and on top of the gas tank. Thats helped a little. The helm gets a vibration that finds an annoying resonance. Every year I work a little more to quiet this boat, and every year I find more things making noise.
Ray525
I did notice when i checked the plug on swim deck it was filled with water .im hoping plug wasn't seated right...back on water tomorrow , we will see!!!thanks for response!!!
Midnight2V
Houston Area
This is pretty typical, my boat does it too and every other single engine 1.8 I have been on does it in NWM. What I have found is that if you push the throttle forward to completely raise the reverse bucket (instead of the 2/3 setting just off of neutral), it calms down considerably. When I run low speed in manual at the same RPM, it is significantly less as well.
Ray525
Ok, still getting a feel for this, and all of sudden you hear something I start to think the worst..thanks.
haknslash
Lake Martin, AL
Moomba
Normal if you're talking about No Wake Mode setting 3. At that RPM it's just a sweet spot for harmonic vibrations IMO. As soon as you go a hair more or less RPM it's gone.
Ray525
njmr2fan
Augusta GA
Can NWM be adjusted to different RPM points?
haknslash
Lake Martin, AL
Moomba
I don't think it's adjustable other than the 3 settings we have. Maybe Ridesteady or PP would work but I don't know if you have to have the throttle beyond the first detent or not.
2kwik4u
Georgetown, IN
Mine does it bad as well. NWM at setting 2 or 3 makes the storage area cubby rattle terribly. I cut a small piece of foam I had sitting around and stuck it to the corner of the door to keep that from happening.
Seems like every outing I find another source and have to find a remedy for it. Overall minor complaints though.
pete4180
On my Boat NWM setting 2 or 3 is the sweet spot. On setting 1 the whole boat vibrates.
haknslash
Lake Martin, AL
Moomba
Want to see something funny you should open the engine hatch while in NWM. You could turn the engine into a paint shaker at those RPMs. They move a lot with the rubber motor mounts. Imagine the vibes we would feel if they were solid mounted lol
Jeel
Toms River NJ
Glad i found this thread,,this 2019 AR 240 is so much noisier than my old SR 210...i thought something was loose
Cparker2
Lake Oconee, Ga
Man I have the shakes at 1900 rpm. A touch more or less no problem.
That cavitation rattles my fillings..
njmr2fan
Augusta GA
That RPM rattles the steering and other hardlines that run under the flooring. I took pool noodles and ran my lines through them. they can rattle all they want now, at least i can't hear them.
mwalker4
Delaware County, Ohio
NWM 2 -2000 rpm is my bad rattle spot. I'll have to do the noodle trick this winter. Some things I get used about the boat, but bad rattles still get on my nerves. It's done it since day one. At least it's bone dry, that would bother me more.
