msavold
- Columbia, MD
- SX
Finally able to get the boat back from storage! Spent the week end deep cleaning it (my wife had to comment that she'd never seen me clean something other than my teeth with a toothbrush!) and when I got to wiping down the throttles the starboard engine throttle would not go from reverse to forward. It'll move through the 'speed' range but when it comes to the point where the bucket has to move no joy.
When the boat went into storage, the last thing I did was winterize it so I know the cables were working properly at that point - a bit stiff perhaps but still working. When I store the boat I try and leave in reverse to keep the gate closed over the nozzle - and now it won't open. I've checked for the traditional rock stuck in the gate issue but I can't find anything that looks like a culprit. (BTW, boat is 2012 and used in salt/brackish water but flushed/washed with salt away after every outing.)
So, where would you start? I'm thinking step one is to disconnect the cable form the gate and see if I can get it to move or, given its age, assume that the throttle cable is screwed and replace it?
If it's the cable, is it one piece from throttle to bucket or two? From the service manual, it refers to 12 as the throttle cable and a connector cable (15)? And what's with the "remove air cleaner top" line? I don't remember seeing that in any of the cable replacement threads but I'll look again...
Thanks!
Thanks!
