Ocean use for Yamaha AR 230, tips or comments
David Dixon
Just discovered this site and registered right away. Wondering if anyone has any tips for use of Yamaha AR 230 in the ocean. I am in process of buying one and it will be based in Cape Coral FL where I plan to use in the big river system there and out into the Gulf. Everything points to this being a great family fun boat with great stability and performance. How is the boat in less than calm waters etc and what should I do maintenance wise after each salt water use.
I'm a Great Lakes boater with many years of family boating so while new to a jet boat not a novice in the water
Thanks for anything you could offer
Cheers
ToddW850
Destin, Florida
Welcome to the Forum @David Dixon ! I have the AR210 and boat in the Gulf of Mexico all the time. As far as going out into the Gulf, you'll learn your limits (as far as waves are concerned). When going through the Pass into the Gulf, always keep your bow up and no need to speed through.
After each use, wash it down good with soap and water and wouldn't hurt to run some Salt Away through the engines during flushing. Spray the engines, clamps, just about everything with some YamaLube/T-9 or something of the like. Also, get into your transom area and spray all of your hose clamps down real good with YamaLube/T-9. Last year I found a couple that had rusted and broken. I replaced all of my clamps with new SS Clamps and sprayed them down.
David Dixon
Thank you for that swift response and great tips especially switching to SS clamps, will save on dramas on the water later on
I can't wait to get out there!
Andy S
Chapin, SC 29036
Cobalt
@David Dixon Welcome aboard, glad you found us!
These boats can handle the rough ocean/gulf water just fine, you and your passengers will be the limiting factor. One thing about these boats is that they boob on the surface, they don't plow through the waves unless you have trim tabs on your boat. The boobing could cause a rougher ride than other boats of similar size.
There is a group of us that aren't afraid or don't know better, we take our boats to Bimini, Bahamas each year. Here is a link to this year trip https://jetboaters.net/threads/bimini-2015-july-6th-to-11th.2647/
Scuba_ref
Wenatchee, WA
I got distracted by the words Boob and Boobing. If that happens regularly in Florida then I really gotta move there. Not much boobing going on up here! :winkingthumbsup"
Andy S
Chapin, SC 29036
Cobalt
Good catch, i'm good at spelling but not always using the right word.
Obviously boob should've been bobb.
Scuba_ref
Wenatchee, WA
Well, that isn't nearly as interesting. Nothing to see here, please move along!
David Dixon
Hey Guys, as a new member I didn't think it appropriate to correct a member of good standing but I do like boobing in the water especially those not yet seen!
As to the bobbing, need to check into the trim tab situation as there is a reef about 4 miles out from Sanibel Island with great fishing that I will be going to often
Looking forward to eventually meeting some of you on the water or maybe watering holes!
Cheers
