OEM alternator capability for 2 batteries?
adamsrotors
Sacramento
so I installed a 2nd battery with a 1-2-1+2-off switch...
I tender them both when parked.
I'll run both to get around and click into 1 (the new battery) for stereo only, when anchored.
we had a few times now where the check engine goes off (over n' over after being cleared) and almost positive it's a low-voltage read. (I need a reader...anyone have link to cheap one?) or is that not a thing? but, even tho I was in battery 1 slot and the 2nd should be damn near full...I feel like I'm not charging both batteries enough.
my question is, is the OEM alternator sufficient to charge up two batteries?
anyone else running 2 batteries and ever have an issue?
jtwrace
Orlando, FL
PWC
How do you charge them? To properly charge them you have to charge them individually unless you're using a multiple bank charger; otherwise, one battery isn't fully charged to 100%. You can use a DMM and should see a minimum of 12.65DCV for them to fully charged (this is for an OE lead acid).
As for the reader, I personally own the CanDOO but it's not inexpensive...I'm sure some other people have feedback for another option. The check engine is doubtful for battery voltage...you should have a battery voltmeter telling you what's going on there.
adamsrotors
Sacramento
I charge them individually...
any thoughts on OEM alternator tho?
if anyone can link me to a cheap reader, it would be greatly appreciated.
adamsrotors
Sacramento
^ show's how much I know! stator*
and there you have it...upgrading to a nice on-board dual bank now.
that'll help for sure and I know I have them full charge at same time and also great for when I'm on the water overnight.
marcham
Comox, BC
AR195
Are you able to retrieve the code for the check engine light? I believe the procedure is in the owner's manual.
As for voltage and charge capacity, it really depends on how you use the battery. Deep cycle batteries don't charge fast. So if you draw 70Ah using a stereo, amps and lots of speakers for the day then drive back to the dock for say only 1 hr, the battery will not be recharged.
