2kwik4u
- Georgetown, IN
As the season is winding down for us, I'm looking at doing the oil change on it here soon. I'm at 67hrs, so I missed my 50hr change by quite a bit, and want to go ahead and get it done.
As I'm gathering parts, and reading how to's and planning my maintenance, it occurs to me. I don't have a level spot to do the work. The boat stays in the garage, but I don't want to run it in there with the water on to warm it up. I would prefer to run it on the hose in the driveway. If I do that, then the driveway slopes "downhill" considerably, and I would have to run it on the hose, then back it into the garage to change the oil on a level surface. This will involve dropping the tower, backing it in, then raising the tower back up. How long will the motor stay warm once I've run it up to temp? Will I have 15min to get it in the garage, and leveled? Can I change it with the boat NOT level and sitting in the driveway? Do I need to find a buddy that is sympathetic to the cause and change the oil in his driveway?
Here's an idea of how steep/slanted the driveway is. The garage is the only flat area I have available at home.
The next question......What part of the boat should I level when I change the oil. I'm assuming I can put a spirit level on the valve cover and make that level, and that will get me the appropriate amount of fluid pumped out once warm. Is that correct? Should I tilt the motor nose up some to get as much oil to the back of the pan as possible? What is the correct orientation for this process?
Finally....where is (or does it even exist) a drain valve on the oil pan? I know that standard practice is to suck the oil back up through the dipstick tube, however I was thinking that once I had it somewhat emptied, I could open the drain valve in the pan, and replumb that with a 1/4 turn valve, and suck the oil from there on the next change. Making it more like a full drain/replacement of the oil. Is that over thinking it? Is it possible? Has anyone else done something like that?
All my boat experience in the past has been with "marinized" GM engines where a drain plug in the pan was accessible, and used to change the oil. Typically with a small tube run through the hull drain plug and into a catch can. This purpose built marine engine is new to me, but I suspect the idea is the same.
