Mister Fister
- Sevierville, TN
I am just getting around to doing my 1st oil change as the second owner on my 2018 AR190. It has 150 hours on it and I have no records of the previous owners maintenance so I figured better safe than sorry. I checked the oil (cold) and it was right at the low dot on the dip stick. I used a manual pump extractor and only got 2.25 quarts out (cold). I adjusted the nose of the boat up and down on the trailer and thats all I could get out. I went ahead and changed the spark plugs and oil filter but I do have a question regarding the oil level. I put 3 quarts back in and the level is in the middle of both dots. Is this a good amount of oil to have (cold) or should I add a little more oil? Would it be best to run the boat on the water and check level then?
