- Select Rotax JPS
- Last two letters of you engine model number
- HP
- Engine type
That allows you to look up all part numbers from BRP. Not Scarab stuff. Note that some stuff like the jet pump is only shown in one of those types. In your case, just like me, the pump is under the non cat option. If you then select the Jet Pump option, all the parts are shown and the corresponding part numbers below.
Note that many BRP part numbers have equivalent Sea-Doo part numbers. Unless you have a Scarab dealer to ship stuff to you, you'll have to figure out what the corresponding Sea-Doo part number is so you can request that from any of those dealers. They won't know anything about BRP part numbers.
- Shaft seal I assume you mean the carbon ring? If so, BRP#0461970 under Driveshaft section.
- Sleeve I assume you mean the impeller boot? If so, BRP#0460136 under the Jet Pump section.
- O-ring, that depends on which one you're talking about. If it's the one by the carbon ring, Part 110 BRP#0460334. If you're talking about the two O-rings inside the impeller cone, BRP#0460333.
But obviously crosscheck everything. In case I'm not interpreting what you're asking correctly.
Not sure if there's something "better" for the plug. I use what is recommended by BRP which is that one. It has served me well and lasted 3+ seasons before finally giving out. The letter E at the end is important btw. It has the removable nut. So if you do get that, make sure it's definitely that one because you'll need to remove the nut to get the coils to fit properly.
Hope this is helpful. Feel free to PM me if you have more questions.
You can also PM me via Facebook if you prefer instant back/forth:
Luc Lafrenière
