Oil consumption
Joe Costa
LS
How much two-stroke oil should I use for every full tank of gas used on my 2000 sl2000 yamaha twin jet boat?
glad to have you on board @Joe Costa
I'm sorry I don't have an answer for you,
How long have you owned your boat? have you upgraded the oil lines ?
maybe @4x15mph or @Speedling can help,
Depends on how fast you go! It is a variable speed pump and is not always directly related to gas consumption.
I upgraded my lines and forgot about it. I did check that oil was coming through lines since they were clear/yellowish and i could see it. If worried, make a little premix and run it till you are sure. You want to run premix if taking a line off to see it come out.
Why do you ask? Something worry you?
Just would like to know what the oil consumption should be per a avrage tank of fuel.
It has the clear oil lines with wire ties holding them on the fittings. i am having them replacet thursday with new lines and filters.
I am sorry, i never kept track. I more or less just verified it was using it.
I have not really kept track of oil consumption, just that it was using it. What I can tell you is if you use these boats for what they were intended, "going very fast a lot" you will burn a heck of a lot more gas than you will oil. Which I am 100% ok with..
Sorry I forgot, WELCOME!!!!! @Joe Costa Glad to have you here..
Are you talking about for pre-mixing?
If using the oil injection, I think it is about 50:1 gas to oil except for at idle since the pumps are variable. You have a 40 gallon tank so less than a gallon (.8) of oil for each tank
