Oil tank vs mix
Fastjet
LX
Hey guys new here read a few post on oil lines
Replace on older model or mix my own gas n oil
Beachbummer
Houston TX
Most oil pumps are very reliable and offer variable mix, so you smoke less at idle and low RPMs but still get full lubrication at full throttle. Both Sea-Doos and Yamahas have issues with the little hoses used to route the oil. Keep the hose in good shape and it should last forever.
There is a very small chance of oil pump failure, and some folks prefer premix for that reason, and don't mind the extra smoke and expense in extra oil.
Which is right for you? Hard to say. Hopefully others chime in with their thoughts to help you out on your decision.
Fastjet
LX
Hey ty for info I’ll make sure lines r good when I get that far with it
Just bought from friend changed steering cable today not to bad hr
R so but has bad control cable dam frozen screw broke off that holds them in place hope didn’t get in to deep lol ty again beachbummer
