OK I am suposed to be working but I have a wake surf question!
gthh
Buffalo, NY
I just got the Liquid Fish 5'6" board and now how do I get it on my boat. I stalled on the purchase (cost, number and type) of a wakeboard rack for my AR230 so now I am stuck figuring out where to store the thing when I am underway! Should I strap it on the tower(bungees) or try putting it in the locker?
Also I have one board but does any one have any recommendations on how many racks (based on experience) I should get and any comments on what I should get? (cost is a concern)
We store wake surf boards in the bow floor area.
It will not fit in the ski locker.
007 made strapes to hold the boards under the Bimini , worked out pretty slick , mabie he will chime in
With bungie cords I use my tower as a ski rack. It works well using a tiny bit of padding and 2 bungies. Cam.
I did this for about $10. Used the straps off an old cover, bought a few extra webbing clips and some pipe insulation. Got my wife to pull out her sewing machine and with a little trial and error, made "under bimini surf racks!". Still using it a year later. Have to have the bimini up, but we surf with it up mostly anyway. Sorry I cannot find more pics, but you'll get the idea from this one:
That is awesome! Does it hold 3 boards?
No. I meant it to hold 3, but the space is too wide where the bimini covers the bow in the center, so you can't tighten the straps enough to keep a board in place in the center. You'd have to modify the bimini and I just wasn't up for that. But it holds 2 really well!
Too cool!
@KXCam22 Do you have any pics? I have not used the bimini yet so would like to see options with just the tower.
Thanks!
Love this and the pockets on the top!!! Brilliant!
Sorry no pics but you can hold 2 boards easily. I put mine on the top side as they will stay there while you bungie. You could use pool noodles for pads or those pre-made canoe blocks. We don't use our bimini. It worked far better that you would expect. 007's setup is primo. Cam.
We keep it on the floor as surfing is usually single purpose lake trip.
This might solve all your problems....
Buy an inexpensive, yet durable, set of racks for a hundred bucks. That's right, $99.99 here:
http://www.bartswatersports.com/cat...it/index.asp?gclid=CNz9-7S39L4CFc1lfgodvz0A2A
(Boater's World carries them also)
These:
Then you cut the middle finger out of one set - it's billet aluminum so it shouldn't be too hard. Grind the contour smooth with a drill/sander - and viola! You have a Board Rack.
Buy another set to carry two wakeboards on the other side and you've spent $200
Problem solved for 200 bucks and some elbow grease. OR, you can buy one that has a place for one board and one wakeboard for $189 - $250:
http://www.wakeessentials.com/product-p/bar002.htm
http://www.wakeessentials.com/product-p/bar007.htm
:cool:
Great Ideas everyone. I think the Bimini one 007 suggested will be the one I go with tomorrow. I will probably order a rack but who knows a little ingenuity by 007 may have saved me some dough!
I don't have a tower, and I have been curious as to where everyone else stores their surfboard(s). What @007 has done is awesome!! If you are able, do you think you could post some up-close pics of how it is sewn? I think that is a great idea!!!
