Old wired remote
Scott griffith
Pensacola fl.
SR
Was wondering if anybody had a old wired remote off there factory head unit like in the pic
Which year is it? I have this off an 2005 AR230
I believe it's off a 07 really just looking for the wiring
If you are splicing at the remote, you could just cut the plug off and splice wire to wire.
Looking at wiring up two remotes really need the wiring with the black plug on it I already have a splitter
I'm literally outside trying to take the old one off. Replacing with Fusion MS-NRX300. At any rate, the 2 screws just spin.. and spin and spin. After struggling to slide my hand up around to the back of one screw doesn't appear any bolt or anything preventing the screw from backing out all the way. Maybe there is some sealant holding the back plate on. Should this thing just come off. I'm about to just break it off. :)
Pry with a flat blade screwdriver while reversing the screw.
