One and done...
Sean Scarab 195
Long Beach, CA
Last weekend, I sucked up my 3rd rope and I'm really bummed about it as my boat sits in the shop needing repairs $$$. I've only had the boat 15 months.
First rope: lobster hoop netting on a dark night. Nearly sank the boat, towed 30 miles back from Catalina island, required new engine.
Second Rope: Dropping anchor on a dark night while boat-in-camping, towed 30 miles back from Catalina. $200 repair.
3rd Rope: Trying to be helpful and pull a guys boat stuck on the sand. We spent an hour getting the rope out, dropped the boat back in the water, get up to speed then engine dies and bilge starts cranking. In just 5 minutes, the boat fills with water. Boat is in the shop now waiting estimate.
I'm curious: How much water can one of these Scarab boats take in from a broken seal? Will they sink or just fill up really good with water?
Ronnie
SF Bay Area
Wow, a new engine because of a fouled rope, that's terrible. Good luck on this latest round.
Robert Sands
Toronto Canada
HO Impulse
Carbon seal is a death blow if you're on the water. It will sink completely.
ScarabMike
Green Cove Springs, FL
Sucking up ropes and debris into the pump of any boat or PWC can cause damage. And also depending on how you react or address the situation can also be a factor on how extensive that damage is. One scenario can lead to another for example:
Suck a rope that shakes the engine. You clear the issue, and everything looks ok. About 10-15 hours later, your carbon seal fails because the engine shook out of alignment. Or, maybe you have your engine replaced due to an unrelated problem, and the service center does not check over their work, and the exhaust pipe becomes loose. Now you have a 3" hole in the hull.
In the end you have to be cautious, but its inevitable that you will encounter an issue like this one day just because of how our boat's propulsion system works.
