In need of superchargers for 2014 215HO
John P Jones
HO Impulse
My 2014 Scarab 215HO is finally at the hrs where I need to rebuild or replace the superchargers. Found out that the superchargers have been superseded a number of times, and the units on my boat are no longer available. So I’m looking to buy/install the latest model- except no latest models are listed for my boat. At the moment, it appears I have 2 options: run the boat until the superchargers explode (not a good option), or, use the boat as an expensive lawn ornament (also not a good option).
Have others run into this? Anyone know what the current replacement pn’s are? The dealership could not find it (yet). There has to be something that will work. The rebuild kits aren’t even available.
In case someone can help;
Hull ID:
PSBSC083E414
Engine IDs:
440010AAA/09440560
440009AAA/09439913
I've seen many reports of folks installing the "maintenance free" versions. To my knowledge, it's entirely possible to update to that if that's what you want. Keep in mind that the maintenance free ones still need to be inspected every few years, slip checked, etc. From what I know, they are better balanced, etc. But like anything they can most definitely wear out. At that point you either need to replace the entire unit (which is what Sea-Doo/BRP does), or get an aftermarket company to rebuild them (which CAN be done).
The alternative is to get yours rebuilt of course. Definitely cheaper but I can't quote numbers.
I
Exactly. I’m looking for a maintenance free version. Problem is, dealership can’t find the right PN for the 2014. Seems like there isn’t one. And the rebuild kits are no longer being made. So I’m stuck at the moment. If I removed the superchargers and sent them to someone to have them rebuilt, that shop would need the rebuild kits - which are no longer made. A bit of a pickle.
I imagine because the older models don't come with the new supercharger. But I'm pretty sure if you get the recent supercharger, it fits on the 2014 just the same.
Just send your supercharger to a company like Greenhulk. I can almost guarantee they will have the OEM parts to do it. They do a ton. Contact them first. They use OEM parts.
Got a set of superchargers. Lafayette Sports down in Louisiana were Very helpful. They contacted manufacturer to get the most recent superchargers that’ll fit. Not I just need to dig in and swap the out. Can’t find anyone in Ct that’ll do it for me, so I’m the stuckee.
Will see how that goes.
New superchargers installed. When I removed the originals and did a comparison, the originals still looked brand new. Gears were in great shape. Bearing play was the same as the new units.
Auto racing friend of mine took a look - he said these are “pro-chargers”. A hybrid between a turbo and a super. He was shocked at the 200 maintenance requirement - in auto world, similar units are expected to last the life of the vehicle. Makes me wonder the real reason for these units being so different.
Marine use Is just so different that auto.
Car engine might spend 10 minutes above 5000rpm in it's lifetime...
It's more like 100 hours out of 200 hours for These ...
Different animals
Different animals
Could be. I know they’re different animals. The mechanic races - so his vehicles are used pretty hard. I don’t push my boat too hard. Used for some non-professional skiing, so staying around 5k, but yes, that sounds about right - 1/2 the time around 5k.
Anyone want a pair of superchargers, $500 for both. Out the door, delivered, the new ones were about $2200.
