Online source for Rotax parts?
Floyd
Tampa & Maine
Impulse
I put the boat into the lake this spring and it's only running on two of three cylinders. The third cylinder was cutting in and out, but now is out.
I did all the recommended diagnostics that I could gather from the Rotax service manual without any definitive results. The error code on the dash says PO300 and PO303--Cylinder 3 not firing. At first, PO301 came up, but went away, thus the PO300(multiple misfire detected) error.
I swapped the spark plug and spark coil/spark stick between cylinders 2 and 3...error code still 303... so I guess I need a fuel injector.
I want to order new plugs and a spark coil and an injector.
Anyone know where I can order these for the Scarab/Rotax 200hp/2016 engine?
BobJohnson
Highland Park, il
Chaparral
VR
Elio195HOI
Miramar, Florida
HO Impulse
You're Best bet will find a Sea-doo parts dealer and cross reference. Try SBT, They sell parts for BRP motors but again, its not a Scarab Directory so you'll need to poke around and do some research.
Floyd
Tampa & Maine
Impulse
I found the spark coil and plugs at a local Seadoo dealer up here in Bangor Maine. I never transferred the warranty, but there isn't a dealer up here for me anyhow. Now I need a part # for the fuel injector on the Rotax 4-tech 1503 200hp engine.
JetTech72
SeaDoo
Challenger
Check out : epc.brp.com
Injector : 420874834 or 420874846
Ignition Coil : 296000307 or 420664020
Scott E
Rush NY
SeaDoo
Challenger
For the injector, pull it out and get the part number from the side. It's not a "BRP" injector, my boat has DEKA #109031 48 lbs injectors. It's the 215 hp motor. All the motors with the ITC have the same injectors.
BobbyP
Glastron
GT
Best place I have found for parts is Crowley Marine. Just put in your model number and choose parts from schematic.
Jwood1508
Jacksonville
HO Impulse
Hi Floyd,
I know it's been almost a year but was the the issue with the boat? I have a 200hp Rotax getting P0300 & P0303. I changed the plugs, swapped the coils around and still same code. I was thinking injector or low fuel pressure.
Mrhonnesty99
255 G
Hi Floyd,
Injectors , same issue on the jetski every so often .
