Order of the Forum tab's buttons/links on a smartphone vs webpage
jetboater4life
Rochester, MN 55901
Ok I'll admit this is a minor nitpick, however maybe there is an easy fix for either me or the site. When viewing from a web browser, the New Posts button is the second from left which is fine and great. I use the New Posts link the most. Now when I view from my smartphone the New Posts link is on the drop down menu instead of second from the left, so I have to click that small button to get the drop down menu and then hit the new posts button. On the smartphone app it's Recent Posts, followed by unanswered posts. Like I said it's a minor annoyance, but I am curious why the order of the buttons/links for the Forum tab isn't the same between the webpage and the smartphone app?
itsdgm
Too funny. I've always wondered the same. On my iPhone "new posts" is the first option. On my laptop it's 3rd or 4th (not sure exactly, I'm posting from my phone). It is different if viewed on my phone in horizontal vs vertical too.image.jpg
Bruce
Royal, AR
If you turn your phone sideways (horizontal) the new posts link will appear.
jetboater4life
Rochester, MN 55901
I have an android S4. After turning auto rotate on, that didn't work for me. I still see the same first two selections as I mentioned before, and everything else is in a drop down list.
Bruce
Royal, AR
This is what I see vertical
And horizontal
The menu displayed is dependent on the width of the browser window. Your Galaxy S4 should have sufficient resolution to see what I see in horizontal.
Bruce
Royal, AR
Looks like an Android vs IOS issue. IOS shows a search icon while Android shows the full search box causing the menu to collapse. I will look into moving New Posts next week. The current arrangement is the result of previous requests for menu reshuffling. The menu is buried pretty deep in the code and some of it is implemented by compiled code so I may not be able to move New Posts.
jetboater4life
Rochester, MN 55901
Ok, there is no need to rush. Or if it's too much work, don't worry about it. Save it for a rainy day maybe ;) Thanks.
txav8r
Lake Ray Roberts, Texas
If you move it now @Bruce , the masses will have to adjust to where you move it to...just something to consider.
Wayloncle
73703 Enid, OK
I always use Recent Post...it shows up first on mine.
