ForrestM
- Lake Martin, AL
- FSH Sport
So apparently I was not as level as I thought when I added a little oil after an oil change and I overfilled. Both engines started fine and I'd only gone about 100 yards or so just a little above idle when I looked back and noticed one engine smoking pretty bad. I shut if off right away. I used the other engine to very slowly get to a quiet slough to check on things. It was indeed overfilled. What do I need to do? Any advice is greatly appreciated. I'm assuming siphon excess oil out, clean and possibly replace sparkplugs and replace air filter.
