P013 Fault code
Fluffy
195 ID
This weekend my 2019 195ID threw the p013 code. the Interwebs say that's a valve stuck in bank 1. While rinsing the motor the check engine light went away, and didn't come back. So i'm thinking i should be ok, or am i needing a trip to the dealer?
It was in salt water full of jellyfish and it was HOT out, think ,maybe i sucked up a big jelly that clogged something up and i knocked it loose when I cleaned the boat.
P013 is your downstream O2 sensor need to be replaced. You can run like this as it will not affect the operation of the engine.
If you want to replace it yourself, check for BRP 707600872 or BOSCH 0258006956
