WREKS
- Port Saint Lucie, Florida
- SX
Thanks for reporting!
The head gasket in post #8 of 'Milky oil 1.8 NA Part 3 Engine Disassembly,' never did get explained. On the right hand side, it looks like the gasket was totally compromised. Is that why you sent the head out to have it milled? Or did I miss something? Gasket in Post# 8
Not completely clear to me that your oil was water-foamed from the pic (versus contaminated with something else). So I would do a change and see if it repeats. If it does... well, then you still have an issue. Seems like a cheap test to me.
Dunno, but I doubt leaving the oil cap off is the solution. Seems to me you then run the risk of introducing as much if not more contamination than releasing any contamination...
It is not uncommon after a flooding to have folks change the oil 5+ times before they are back to normal oil. Be patient. Change the oil and run the mess out of that sucker. The heat of running it will run off the water. After a few hours of running, change again. If you are doing that and see it not getting better or getting worse, then you have something about which to worry. If it is getting better, that is normal and what should happen.
I would try the pressurizing cylinders as in leak down testing. If you get #1 near TDC, #4 is also at TDC. Same goes for #2 and #3. Compare your results! There is probably only one place where water/condensation/steam is contaminating the oil. I still think either the head or exhaust manifold gasket is leaking. I think it would have been better if the mechanics had dressed those gaskets with a sealant when they reassembled the engine.
If you were able to remove the engine from the boat, you could probably remove the head. You would just have to rigorously follow the service manual. If the oil changes come back milky, you should consider it. You hàve the skills.
