Boat Stuff Perfect Pass Star Gazer Wake Edition $700 **Price Lowered-Again!**
gobecauseyoucan
Mercer Island, Washington
Complete set up, brand new, never been installed. Includes JBP gauge housing for 2015-2017 24' 240 and 242LS non E boats.
Perfect Pass $1399.95
JBP Housing $149.95
Send gauge to JBP
for required gauge
install $75.00
New retail cost $1625.00
Sale includes shipping
in US-Canada $700.00
pp-1-jpg.67049
pp-2-jpg.67050
pp-3-jpg.67051
pp-4-jpg.67052
pp-5-jpg.67053
Yes, I still have it all,,, New never installed or used in any way. Less than half price at $700.00. Thanks for your interest!!!
Let me check with Perfect Pass on Monday, to see if I can make this work on my boat, and I'll get back with you. Thanks!
Ok cool , I've been wondering too if it works with the MR1's. Probably will need to get a new gauge, since mine is mounted in the JBP housing for the 240-242 boats.
“Should” I would think. Gauge looks the same as what I have on mine. The throttle mechanism mounts on either side of the engine compartment. And throttle cable gets routed to the box and another cable then goes from the box to the engine, if I understand it right.
I can take a couple pics of it installed, if you get that far or are just curious.
My throttles are mechanical not electronic. I have cables that go straight from the throttles to the linkage. I'm thinking it could probably be made to work, but want to make sure.
Same here. I’ll take some pics when I go out to mow in while.
Edit to add pics
5D15D13F-D278-4CDB-9E84-7D40FA91EFCF.jpeg 9AC0AB47-CFFD-4FA4-8885-213B466BD3D1.jpeg 87207755-2A9E-4F5A-8C49-0FF98239AE2F.jpeg 4B24B9C2-146A-48D3-B0CD-BC847CE834D9.jpeg DEE3C313-78BA-4C73-B8C5-9FFD7A1087A1.jpeg F04F9DB7-33B1-475C-A56E-86D7D1431619.jpeg
Hope this helps in some way. Remember, I’m not really mechanical, so only have a vague understanding of what I’m showing here. Lol
@BigAbe75 This picture is from @Julians old boat with Perfect Pass installed on the MR-1 engines. These are the same engines that I have and I think I will have to have a setup like this. Because the throttle cables go straight to the throttle body linkage.I'm going to check with Perfect Pass though to see if the newer style could be made to work though.
Yes it can be modified to work on MR1s. If I remember correctly its $200 in parts. You'll have to transfer the motors to the new brackets by drilling out the rivets. Its not terribly difficult if you're mechanically inclined. There will be a couple extra parts you will need for this conversion because the display in this case does not have a back to mount into a standard gauge hole due to it being a specially made pod.
Cool! Thanks for your insight @sethman919. Is this something you've done before?
