Preparing for the L13 cone install and testing, I had to tackle the old problem, LOL - what grease to use (inside the cone)? Have seen anything from bearing grease to grease-gear oil mixes to oil baths used in those applications.
Not to complicate things, I wanted to stay with the OEM solution. The OEM pump grease is lithium soap based, nothing special there, but it is semi-liquid (so not available in regular grease tubes) and has very distinct specs for high pressure/low temp pump-ability. It is not readily available (and in fact elusive, as many here know). It is not a regular maintenance item. (I think it should be, as water intrusion is only an o-ring away, but that is for a different discussion).
I'm sure there are greases with better specs, but I figured the OEM solution may not be a bad idea given:
1. the shear number of Yamaha pumps in use with no evidence of problems
2. I have yet to hear of a pump bearing failure caused by anything other than water intrusion
3. once you have water intrusion, there is no magic...
So, I (finally) found the OEM pump grease! Well, finding it in 55gal barrels is one thing (easy), retail sizing and available in the US is another. After lots of searching and few phone calls, I am 99.9% positive this is the thing. I have it ordered, have not received it yet.
So, here is what Yamaha puts into the pump bearing cones in Japan (called "EPNOC grease AP #0" or "EP" in the schematic in service manual):
http://www.noe.jx-group.co.jp/english/products/lubricants/e71_enprlu_grease.html#product_0
The US equivalent is "Mobilux™ EP 0":
http://www.mobil.com/english-US/Grease/pds/GLXXMobilux-EP-Series
The source of Mobilux EP 0 (for retail quantities):
https://redidriver.com/my-redi-driver-store/8-oz-ep-0-grease-for-redi-driver-free-shipping-in-usa/
Will see when I get it, hopefully that is the thing!
