biffdotorg
- Pelican Rapids, MN
- Limited S
Did these fit without modification or stretching of the hose? Trying to determine if I need 1/2 inch or 3/8 for our 09 232.
As mentioned in an early post. either will work as all of us have used one or the other. It's hose, it's meant to be stretched or crimped. If you have to ask, it's better to stretch, than to crimp, so go with the larger. But after a couple years, with proper crimping, the small have worked without leaking for me.
Worst case, get out your calipers and measure, they are not hard to get at.
