Pioneer Class-D amps for sale
maboat
Lake Ray Hubbard, TX
I have 3 barely used (1 season) Pioneer 800-watt Class-D amps for sale. Two are 4-channel and one is mono-block (sub amp). These are very efficient and compact medium power amplifiers. Absolutely nothing wrong with them. . They cost about $175 each new. I'm asking $75 each plus shipping but may include free shipping if one person takes the whole set.
These are stock photos but they are all in like-new condition. I will attach actual photos when I get back home later this week.
The two 4-channel amps are model GM-D9500, specs are (CEA-2006 compliant):
  • FD Series Class D 4-Channel Car Amplifier
  • RMS Power Rating:
    • 4 ohms: 75 watts x 4 chan.
    • 2 ohms: 100 watts x 4 chan.
    • Bridged, 4 ohms: 200 watts x 2 chan.
  • Max power output: 400 watts x 2 chan.
  • Pulse width modulated (PWM) MOSFET power supply
  • 4/3/2 Channel operation
  • Pioneer digital signal amplification technology allows for great amplification within an extremely compact design
  • Balanced isolator speaker-level inputs
  • One-pair of pass through RCA outputs
  • Compression-type speaker terminals
  • Hi-Volt input level control (200mV-6.5V)
  • Variable low-pass filter (40-500 Hz, 12 dB/octave)
  • Variable high-pass filter (40-500 Hz, 12 dB/octave)
  • CEA-2006 compliant amplifier
  • Frequency response: 10-35,000 Hz
  • Dimensions: 8-7/8"L x 7-7/8"W x 2-1/4".
The 1-channel (subwoofer) amp is model GM-D7500, specs are (CEA-2006 compliant):
  • Class-D monoblock 1-Channel Car Amplifier
  • 200 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
  • Max power output: 800 watts x 1 chan.
  • variable low-pass filter (40-240 Hz, 12 dB/oct)
  • selectable bass boost (0, 6, 12 dB at 50 Hz)
  • Class D amp technology and MOSFET power supply
  • preamp- and speaker-level inputs
  • fuse rating: 40A x 1
  • 9-3/4"W x 2-1/4"H x 7-15/16"D
What are you swapping out with!?
I'm interested in the whole works. How many speakers do you run off each amp?
I have a total of 10 speakers. 8 Polk Momo's in hi-pass mode and 2 subs in low-pass mode
I've got 10 db651's and a 12 inch sub.
That is a great deal of power for the db651 Cory...it is not designed to handle 100W continuous. The MM651UM would do just fine however.
These 4-channel amps are 75w at 4 ohms so they would be great for the efficient db651's
I have 4 in the cockpit and 4 on the tower. Where do you have the extra 2 speakers? You could run two speakers off the head unit or you could pair up some and run them @ 2 ohms on the amp which would yield 50w per speaker
I've got two on the swim deck as well.
I stand corrected maboat...I was seeing 3x800w and the 8 speakers driven with 2x800w was throwing me.
