FloJet
- Moore, Oklahoma
Ok gotcha. Makes sense. I did forget you did run new wiring. I do believe 160 kbps is too low of sample rate to tune with tho but you probably know better on that side than me. Before I started using .WAV files, I was tuning my system using mp3 320 kbps at 90-92% volume. The cleaner .WAV tone gave me slightly higher volume to tune with. I would love to send you the file and see if you get different results with that if you ever up for it lol.I am using an app (f Generator PRO V4.1.0) to generate the test tones on the fly. I believe this is outputting 160 Kbps MP3 over the USB connection. I do believe that clipping is occurring earlier at 40hz but the volume control on the PA4a is far from linear and closer to exponential which is why I likely did not observe that. Final speaker level out to all speakers being driven must be tested. sound is produced be sending alternating current to the speakers. The frequency of that alternating current is what dthe magnet reacts to causing the speaker to move in and out. More voltage means the magnet will produce more push and pull at that frequency. More voltage = louder to a point. I tested the speaker level outs on the Polk head unit because I am using that to drive some of the speakers otherwise it is not needed. I did run new 14 or 12 awg knukonceptz speaker wire to all of the speakers. My testing so far has been done in my driveway with the bimini stowed. I would love to test a ws420 to see what gains can be had but have not committed to buying one as of yet. I really like the large Connext jog dial for controlling volume (quick to crank it when once the boarder is up and engines are high rpm then turn quick to reduce the volume once throttled down) all without having to look.
My volume control only comes from my phone. My WS420 volume never changes when I get on the water, Connext is always locked in at 95% volume and I only manage my music from my phone and watch. Every once in awhile I will mess with my sub volumes to compensate for the music I'm listening. This is why I tune the WS420 at full tilt.
