Power loss
Willbvt
AR192
Hey everyone looking for some help/ ideas last year I would get intermittent losses of power never could figure it out then the other day it wouldn't run above 6,000rpm. I checked the sc and it only spins one way. Are there fuel water separators?
Babin Farms
Lower Alabama
Loss of power like it falls on it's face or just a slight loss of power?? How's your oil level? Change spark plugs lately? Any other things that were done to the boat prior to this issue that might have caused this?
Willbvt
AR192
I changed plugs in beginning of May, oil and filter done at same time, oil level was good
anmut
212S
describe conditions of power loss
Willbvt
AR192
More like power surges would jump from 7,000 to 6,500 rpm then finally could only be 6,000 out of it
Babin Farms
Lower Alabama
Have you checked your air filters to see if they're saturated in oil?
Willbvt
AR192
I did check the air filter small amount of oil residue in one side of the filter but definitely not saturated, I then ran it without the filter and did not improve
Babin Farms
Lower Alabama
If your oil level is good while warmed up, plugs properly gapped and running with no air filter doesn't make any difference I would do a compression check when cold and then after it is warmed up to see if there are any irregularities.
Willbvt
AR192
Ok what should the compression be roughly?
Babin Farms
Lower Alabama
150ish or al long as they're all close to each other
Willbvt
AR192
Thanks I'll let you know what I find
Willbvt
AR192
Could using 93 octane fuel cause engine issues, the manual only states a minimum octane rating of 86
Crob83
Indianapolis, IN
AR195
SVHO calls for 91 octane, but I have used 93 more than once and never had an issue
Willbvt
AR192
Ok guys so I wasn't able to compression test yet but I pulled all four spark plugs that were new as of May and they were black with sut. It's seems to be fouling out after getting warm and only runs like crap off the top end
