Boat Stuff Power port and hole saw
justason
SWAG Forum Lead
I have in my possession a power port and applicable Hole saw I will not be using. Based on a conversation here I changed to a different power port.....End result...first come, first served. I offer these parts to someone here for the low low cost of a Fedex shipment, I'd guess to be $8-$10.
this is what I have you are welcome to, along with the 1 7/8 drill bit.
http://www.amazon.com/gp/product/B002QALLOQ/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
http://www.amazon.com/VULCAN-961131OR-1-7-METAL-HOLE/dp/B000UO909I/ref=sr_1_5?ie=UTF8&qid=1406649138&sr=8-5&keywords=1+7/8+hole+saw
FWIW my onboard charger is this:
the on board charger I have is:
http://www.amazon.com/gp/product/B001BSUR2Q/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
The final part I went with was this :
http://www.amazon.com/gp/product/B009ANV81S/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Very cool of you @justason. Not to be negative, just informative so that these don't end up unused by he next owner.
I think I had that charging port once but ended up giving I away because I would have had to cut the plug off of my onboard charger to use it (I.e., splice the power port to the charger's lead) which may be important information for someone claiming it, unless I am wrong about your power port . Again, no disrespect intended I just think it would suck for you to waste your time or the new owner his all for this to end up unused in the trash.
justason
SWAG Forum Lead
Hi @Ronnie Perfectly fine feedback. My intent on this was to use a power cord or extension cord, remove the male end, and splice it into the power plug. This is almost mandatory just to reach the on-board charger and doesn't cause the charger to be altered.
That being said @waterboy has claimed it....I'll bring the parts to Rudy's some afternoon !!
