Thank you, does the plastic cover come off easy?Its on the top under the plastic cover. Should be easy to spot. I believe its towards the back
Yep with a drillThank you, does the plastic cover come off easy?
Yes it only requires a large flathead screwdriverThank you, does the plastic cover come off easy?
Maybe if new, I had to use an impact to get mine off, lol.Yes it only requires a large flathead screwdriver
Yup that is what a real production date looks likeIt will look like this.
