1BadTundra
- 212X
I pulled my pump cones today. It had the original grease in it. There was no water inside and the bearings looked good. My question is, I mixed Lucas Marine grease with Lucas gear lube. When I was done mixing it, it had the consistency of real soft peanut butter. I filled the cones about 90% full of it, then used my grease gun to shoot some grease into thew bearings, then reassembled them. Anybody see an issue with putting that much in the cones? The SeaDoo guys said to fill them up. Before I put the drives back on, I wanted to make sure this was ok. Thoughts?
