PWC Trailer Lights
lokart
Anyone know where I can find submersible trailer lights for PWC trailer. They are 6 inches wide instead of the standard 8 inch. Thanks!
Oh, if you don’t have them, you might want to consider some Heat shrink connectors for the wiring.
Yeah, I use the heat shrink connectors, but I take it one step further. I fill the connector with dialectic grease, then insert the wire for crimping and then heat gun. The heat shrink pushes out the excess grease and keeps water from seeping in. Heat shrink can still let water in so I take this extra step.
