- Royal, AR
- SX
I believe this device is intended to remove alternator whine from the power supply to a stereo.
I bought it hoping that it would help with a hum when using the aux input with a source connected to the boats 12 volt system. A noise isolator added to the RCA cables solved the problem. I did not notice any difference using this noise suppressor.
I could not find any info on what the device was or how it was supposed to work so I decided to open it up. Looks like a ferrite choke and two caps that connect to ground. The larger cap is on the supply side and the smaller on the side that feeds the stereo.
I feel like it would bleed voltage to the ground?
Does anyone have thoughts on whether there would be any value in installing it? I am thinking not.
