jamesk
- PA
- SX
Question about bilge pump functionality.
2017 SX210.
Am I correct....the bilge pump needs to be turned on/ powered by the rocker switch on the dash.
At that point, it has a float switch and will only run if water fills up in the bilge?
My last boat had a rocker switch on the dash, if you switched it on....the pump ran.
The pump had constant power and even with the battery switch off, if water got in the bilge it would activate the float and the pump would run.
If that is the correct, it seems like the set up I had in the past made more sense.
Want to make sure I understand that I need to switch the bilge pump on manually when I use the boat or leave it in the water.
Thanks! Jim
2017 SX210.
Thanks! Jim
