KeepRmovin
- Limited S
What does WOT mean? I'm a newby..
I am not disagreeing on proper break in, but here is my $.02. I have broken in a number of Yamaha engines as per the manual. And whenever it says vary the throttle and don't keep it constant, allow cool down and then run it again. That more or less means, run that thing like you stole it, as long as you don't exceed the recommended RPM's (smile)@KeepRmovin Unfortunately I am not sure the Dealer is giving you the proper info. Break-In is in the Manual and Required. It is also required that you do a 10hr service as well as additional Hr services as you go along. You can't do anything over spilled milk, but you should read everything that is required for your boat and engines, otherwise you could have Warranty issues, or a boat that has many issues going forward. If the dealer is telling you that, you need to find a new Dealer cause they are wrong. The fact that they said that is not good.
Also, if it was my boat, I would have them put that shit they told you in writing on their letterhead and have the dealer owner sign it so if the day does come and you have an issue or warranty work that is denied for lack of proper maintenance or whatever reason that you have something for recourse. Also if you have only the 1 year warranty then it will be on your dime after that. It is your boat to do with as you wish though.
