jet_boater_paul
- SX192
Hello - I recently purchased a 2012 SX190 and on 2 occasions, I had a situation in which the engine wouldn't start while out on the water. The first time it happened, we had been out on the water all day, music playing, and went to start it, but the starter could not get the engine to fire up. The LCD screen then displayed an error: LOW BATTERY with a long, loud beep. A few minutes later, tried again, and this time it started up. The funny thing is, the voltmeter on the LCD read 14.3 V. Got back to the dock just fine. I removed the battery to inspect it, and the sticker showed that it was from 2013 (it was an Everstart with 690 MCA). To be safe, I just bought a new one. I got an Everstart Marine Max with 1000 MCA. Installed it, and it worked great for our next outing. But towards the end of that outing, the same exact thing happened. Boat wouldn't start. Got LOW-BATTERY message. Waited, tried again, didn't start, waited some more, and eventually it started. Almost immediately the voltmeter read 14.3 V. On this outing, I didn't have the stereo on whatsoever - so I know I didn't have any extra electronics going that would drain the battery. I also checked the new battery before installing with my multimeter - read as 12.7 V - so I'm very confident the new battery was just fine.
When I was testing out the SX190, the owner told me that in order for the magneto on the engine to properly charge the battery, you have to be going at least 7,000 RPM. Wanted to ask the community if this info is accurate? If it is, I guess that would explain what happened to me on the water those 2 times, because on those outings we were doing a lot of tubing and skiing, and generally keeping the boat in the 18-20 mph range, and RPMs were definitely lower than 7,000. So maybe the battery was getting drained because I didn't have enough RPM to charge-it while going?
Another question is, is it normal for the LCD voltmeter to read as 14.3 V while the boat is going? Obviously this is a 12 V marine battery --- I assume with the magneto putting juice back into the battery, that that would explain the 14.3 reading? Am I correct to assume that?
Since these 2 episodes, I bought two things: one of those NOCO battery boost jumper kits to keep on the boat, and I bought a trickle charger to charge my battery while it's in storage during the week. But I would like to ask this community if what I experienced is normal? I.e., is it normal that I'll drain the battery to the point where there's not enough juice to start it, due to a long day of low-RPM boating? Or should I be taking more drastic action (taking the boat in to get checked / serviced)?
Thanks!
-Paul
Thanks!
-Paul
