Sroc
- Michigan
- 252SD
There is a linkage I’m not sure exactly what it does but a rubber boot at the end of said linkage has come off and the linkage is freely moving I put the rubber boot back on which was a PIA and secured it with a zip tie I believe I was given that recommendation here from this site? I wanted to check with the greater hive to make sure this is an appropriate fix and what the exact linkages is and is this a common occurrence? I have a 2021 252SD
TIA
TIA
