Radio and lighting upgrade to 2023 AR195
xtreme96gs
Finally swapped out the radio and added some lights. Started with the wet sounds mc1 head unit, md2 secondary display for the swim platform, and shadowcaster 4 zone controller. Found that the factory plug from the Jensen was a molex 12 pin connector available on amazing for about $9- so ordered that and added to the loose wires on the mc1 to make entire unit plug-n-play. Also added a constant 12v independent of the battery switch straight into an empty terminal of the factory plug. The wire is coming off of a a bus bar I’ve added to supply power to the shadow caster, as well as a negative bus bar. Shadow caster is 4 zones, all controlled by the mc1. Zone 1 is going to 12 RGB accent lights inside the boat. Zone 2 is going to the 4 RGB 6.5” speakers. Zone 4 is 4 more of the accent lights on the swim platform, and two 15” RGB led strips in the cavities behind the backrests on the platform. I’ll still be adding 2 drain plug lights to zone 4, two tower speaker RGBs to zone 2, and zone 3 will run roughly 16’ of RGB led strips under all of the backrests inside the boat. (Videos of all lights keeps saying file too large to upload lol)
