I believe this is normal but not sure. I've never checked mine when they were up. I do know that at normal rest position they can lift up quit a bit.Not sure if you can answer this specific question, but I entered the mode, put it in forward and the buckets lifted up. However, they didn’t engage into the locking mechanism. I was able to push them up further by hand and then they engaged with the lock
Is this abnormal?
The reason I’m doing all this is because my dealer had to disassemble the units and they didn’t put it back together properly.
Hi - were you able to make the adjustement in the water or did you pull the boat out? thanksIf you have adjustment at the back of boat, yes small adjustments.
You can also also adjust it inside engine compartment on the IRS
Unit that the other end of that cable goes to.
After I adjusted the bucket I had to readjust my neutral position in dash settings.
hi! were you able to make it work? I have a similar issue, any tips? thanks!I see there's a black ring that can be spun to lengthen or shorten the cable. Is it just a matter of unhooking the cable so you can lift the ring out and spin it? Or do you have to loosen/remove the jet assembly to do it?
