Removing aqua mat
Briwhy
Saxonburg PA
Glastron
GTS
So I started to remove the aqua mat from my boat. When removing the Mat the top layer is pealing off leaving the bottom film behind. Any ideas on how to get this off or do you think I could use fine sandpaper and scuff it up and stick the new marine mat to it. I've tried 3m adhesive remover which worked great for the glue and I also tried a 3m eraser wheel. IMG_20170505_210019939.jpg
Briwhy
Saxonburg PA
Glastron
GTS
@ScarabMike any ideas for me since you just did this. Did the mat pull off like this for you?
Briwhy
Saxonburg PA
Glastron
GTS
Yeah I tried the 3M adhesive remover which worked for the sticky glue but it doesn't seem to wanna touch where the mat pulled off and let the tape part down.
ScarabMike
Green Cove Springs, FL
That was my issue. I soaked a rag, and used a razor, but you have to be careful.
Briwhy
Saxonburg PA
Glastron
GTS
Alright. What's your thoughts on using fine sandpaper to scuff it up?
Briwhy
Saxonburg PA
Glastron
GTS
Alright I'll give it a shot. Thanks
