Five Faces
- Franklin, TN
- 242X E-Series
Has anyone found a replacement bilge pump that has an internal float switch and fits in the same location? I would like to eventually add a second pump but for now need something quick and easy before it sits in the water for a few days. I don't mind leaving the battery switch on as long as the pump isn't cycling like the existing OEM pump.
I would think there has to be a pump with a similar footprint whose auto feature is anything other than the 2-3 min power cycle that measures resistance.
2017 Yamaha 242X
THANKS!
2017 Yamaha 242X
THANKS!
