Ridesteady External Display - Help
Mandiime
Redding Ca
Has anyone installed the external display on a 2019? Where do I run the wire? Do I have to cut a hole? Everything been very easy with no cutting or anything. This last part I can't seem to find a way other than cutting a hole.
Which display? If I remember correctly, the round ones are meant to be built into the dash.
I used a small RAM mount for the square display, works great.
I think post# 6 in this thread shows the mount:
This is exactly what I was looking for.. I just need to open this up and run the wire. Its the display with the RAM mount.
Thank you :)
