waternutt
- Panama City, FL
- Chaparral
- VR
Needing some help on a new active engine fault code. I have the been running with a P013A for a bit with no issues. I understand that is an O2 sensor. The new one that popped up is a P2037. I can't find anything on this one. As before, the engine seems to be running fine.
Also, when I first turn on the key, the check engine light will be on for a few seconds but goes out. It is not on while the engines are running. Is that normal?
