AZMark
- Phoenix, AZ
- Limited S
I have a 212 limited with 6 Polk DB652 / 522 speakers run off the head unit. No tower speakers or soundbar. From what I've read here these are decent speakers, but I think they are obviously underpowered by the Polk headunit. I'm just looking for better sound quality on a minimal budget, not trying to blast everyone out.
I am considering buying a Polk 5000.5 5 channel amp to run the existing speakers and two new DB652 speakers I'd like to put near the helm. Down the road I would probably add an 8" sub to channel 5.
Would running the existing 6 speakers on one of these amps be a significant improvement over the current stock setup? If I ran two in parallel at 2 ohms on each channel it would be splitting 100w. This seems like it would be much better than stock, but I have no direct experience.
If I do everything I'm planning on I will be running 9 speakers on this amp - 2 speakers each, in parallel @ 2 ohms on channels 1-4 and a sub @ 4ohms on channel 5. Do those of you that have these amps (maybe @jcyamaharider ?) think this would be an ok permanent setup or would it overwork the single amp?
